Antarctica
Merge conflict after two people added files to installer.
When files(?) are added to the installer independently by two developers, the row
<ROW Feature="MainFeature" Title="MainFeature" ...
is updated to reflect the changed values.
This causes a merge nightmare in git, since we have are one hundred and eighty values in the main feature, and all of them in this single line. Did I overlook something there that would reduce the number of values? Or could you change the AIP format in such a way that added files are one per line, not all in one?
Furthermore, both developers caused changes to the same file row, where only NextFile changed:
<ROW File="Microsoft.IdentityModel.Xml.dll" Component_="Microsoft.IdentityModel.Xml.dll" ... SourcePath="..\.." SelfReg="false" NextFile="fullpagemasterbundle.js"/>
vs.
<ROW File="Microsoft.IdentityModel.Xml.dll" Component_="Microsoft.IdentityModel.Xml.dll" ... SourcePath="..\.." SelfReg="false" NextFile="adalangular.bundle.js"/>
and now I am unsure what that means and how to fix.
Do you have any advice for this?
Re: Merge conflict after two people added files to installer.
Please keep in mind we do not recommend at all to use the merge operation of your versioning control tool for our setup projects. When you need to commit a change in the setup project we recommend you to commit the AIP file entirely as a binary file.
Have a look on our "Git Merge Issues with AIP" thread debating similar topic.
