asif0012
How to use CustomActionData inside powershell inline script custom action
I am using Advanced Installer version 20.6, Enterprise Edition.
I want to store around 10 properties in one custom action and use it in a separate custom action that will be executed at the deferred stage. The custom action type is "Powershell Inline Script". While using the "Powershell Inline Script" custom action in the deferred stage, I was unable to use Installer property values.
From here, I have found that I need to use "CustomActionData" to retrieve the property values.
https://www.advancedinstaller.com/acces ... -data.html
The example is with a *.vbs script.
How can I get and set the "CustomActionData" inside a "PowerShell Inline Script" custom action?
Best Regards,
Asif
Re: How to use CustomActionData inside powershell inline script custom action
Hello Asif,
Here's how you can retrieve the values of properties during the "Deferred" stage using the "CustomActionData":
If you have more properties to retrieve, simply add them there, like this:
-varName [PROP_NAME_1] -varName2 [PROP_NAME_2]
and then:
Param($varName, $varName2)
