I have an Advanced Installer project that works just fine on an English installation of Windows Server 2012 R2.
Among other things, it adds permissions to the Installation Paths so our services can access it. Ideally, I would like to add permissions to "NetworkService", but since that isn't listed as an option in the Permission Dialog, I have instead used "Network Configuration Operators".
So far so good, and on English versions of Windows, it works just fine.
However, on German versions of Windows, the following error message is displayed during the installation:
An error occurred while applying security settings. Network Configuration Operators is not a valid user or group. This could be a problem with the package, or a problem connecting to a domain controller on the network. Check your network connection and click "Retry", or "Cancel" to end the install.
Wiederholen Abbrechen
Is there a way to remedy this without having to use custom scripts?
Thanks in advance,
Kira Resari
