Abdul-Rahman
IIS and Features
Hi guys,
I need your help in this scenario :
when the user chooses to not install a feature which when installed will be used as the physical path and files for an IIS site I will install ,whether it is in Modification or Custom Installation, I want that IIS site to not be installed if it is a custom installation and delete it if it is a modification.
if you didn't understand ,I basically want to link the site's installation and uninstallation to the feature's installation and uninstallation.
Abdul.
Re: IIS and Features
Hello Abdul,
To achieve this behavior you should just set the "Install condition" field of your web site entry from "IIS" page like this:
(!WebSiteFeature = 3 AND &WebSiteFeature <> 2) OR (&WebSiteFeature = 3)
For more details have a look on our "Edit Condition Dialog" article.
