jrahma
BUG: Prompting for Password
when copying the setup file on netword folder and installing it from there like this:
\\192.168.1.10\setup\setpfile.exe
it will prompt for the password of network folder during the installation unlike Installshield
Hope it will be fixed...
Jassim
Re: BUG: Prompting for Password
Hello Jassim,
If you are referring to the UAC prompt (for user account and password) during installation, please keep in mind this is the normal behavior when using an installation type which requires admin privileges. To avoid this behavior you can choose to use a "Per-user only" installation type from "Install Parameters" page.
Let us know if this helped, otherwise please give us more details about your installation scenario requirements. Maybe exemplify a bit more or attach some screenshots.
