Jaradat
Multible instances ( file and folders conditions)
I have tow folders inside: File and folders -> IIS WWW Root
then Go to component (F8)
then add the conditions :
First File -> Condition : InstanceId="#0"
Second File -> Condition : InstanceId="#1"
Note: i use multible instances in order to create the first file in the first run of the setup, and to create the second file in the second run of the setup
but in the first run of setup the tow files were created :(
what i forget here ?!
Jaradat
Re: Multible instances ( file and folders conditions)
Am tried to define new feature in organization page. and move file 1 to feature 1 and move file 2 to feature 2 , and define the condition InstanceID="#0" for feature 1 and InstanceID="#1" for feature 2
and the same result happen ( result: the both files created in the first run of the setup)
I've tested your scenario but I cannot replicate it. Everything worked as expected.
Can you please try to see if the behaviour still persist when creating a new sample project? If it does, please send us the .AIP(project file) so we can investigate it.
Jaradat
Thank you Dan
Everything goes fine :)
You're always welcome Jaradat,
If you have other questions, please let me know.
