EstebanLopez
Custom SQL Server Instance
I would like to know how to create an SQL Server instance without using the Command Line in the prerequisites. The reason behind this, is that I want my database to be installed in a custom instance (other than SQLEXPRESS) and if the user already has SQL Server installed, the Command Line won't execute, hence he won't have the custom instance I want.
Greetings,
Esteban.
Re: Custom SQL Server Instance
Hello Esteban,
You can see my response in "SQL - Just create a new instance?" thread.
