With an installation with multiple prerequisites, the test is version number and a registry entry. One of the prerequisites works properly and does not attempt to re-install, the other works on some machines but not others. In all cases a manual look with regedit shows the required entry but the installer does not detect it.
The offending file is attached. The offending registry entry is:
HKEY_LOCAL_MACHINE\SOFTWARE\CUSTPDF Writer
The registry entry appears identical on both working and non-working systems (as seen in an export).
