I just updated to build 11.8.62156 of AI.
My installations since then are crashing.
The original program (source of the installer build) runs OK. The installed program does not.
When I compare the two folders and manually update the installed folder with the differences, it still fails.
I am aware that the problem may be mine, but I wanted to know in anyone else was experiencing installation failures with this build.
Thanks!
