Lee Jae-cheol
Modifying the UI of registration page.
Hello.
I have a simple question.
In Advanced licensing, I wonder there are some method to modify end-user's license registration dialog UI.
I guess that The UI's implementation seems to be exist in licensing library DLL.
Please answer me, thank you.
Re: Modifying the UI of registration page.
If you want to display your own custom trial dialog, then you can use the approach exposed in our "Advanced Installer using my custom form for trial.dll" thread which debates a similar issue.
