I have both these options enabled on my project (AI 11.5)
Media->Uninstall a package with the same version (if found) ticked
Upgrades->Automatically upgrade older product versions (selected) - Uninstall old version first and then install new version
i have nightly builds generated on our build machine with version 5.0.2014.1105(yesterdays build) and 5.0.2014.1106(todays build), using scripts we set the build version using a aic file with the "SetBuild <version>" entry
I have yesterdays build installed and i use the updater to "check for new updates", i get told the updates are available and I install them, however, in the control panel i can see both yesterdays and todays versions listed in there
How can i stop this happening ?
Thanks in advanced
Fergus.
