hadas
Uninstall prerequisites (msi and exe)
How can I uninstall prerequisites when my product is beeing uninstall? I have feature based and post-install pre-rep. some of them are msi and others exe.
I read in the forum http://www.advancedinstaller.com/forums ... =2&t=19956 to LaunchExeWithDirectory after InstallFinlize. Running these custom actions I get "Return value 1631".
Hadas
Re: Uninstall prerequisites (msi and exe)
Hi Hadas,
In order to achieve this you can use the "Uninstall using this command line" field from the "Setup Files" tab of your prerequisite. In that field you should write the appropriate command line to uninstall your prerequisites.
