FergusMurray
Synchronize folder issue
Noticed this for the last few releases and is still an issue at 11.5
I have a synchronised folder which i dont wont to sync the subfolders, so i have under Filters->Exclude Filters "Exclude Filters" checked
with this set, if i go back later and DONT go to the exclude filter, and just hit Ok from the "Include filters", it adds all the subfolders that i had previously told it to exclude
I can work around this at the moment, but would be good to get it fixed at some point
Re: Synchronize folder issue
I tested the scenario and, indeed, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
This was fixed in version 11.7 of Advanced Installer released on December 16th, 2014.
