I am getting the following error: Failed to localize one or more elements in the EXE bootstrapper. Make sure that [... ... ] is not being used by another process and the elements used by the bootstrapper can be accessed.
That error began to appear in the last few weeks,the builds before worked perfectly.
I tried to reproduce that behavior on other machine without success, that error is unique for a specific machine.
After many build executions the build usually finished successfully.
Any help will be appreciated,
Thanks in advanced.
