Jaradat
Windows 8 .NetFramework 3.5 (Include .Net 0.2 and .Net3)
How to enable .Net framework 3.5 (Includes .Net 2.0 and 3.0) on windows 8 without connecting to internet to dwonload the package>
when i add framework 3.5 as windows feature it also needs internet to dwonload it.
i need offline methode?
mihai.petcu
Re: Windows 8 .NetFramework 3.5 (Include .Net 0.2 and .Net3)
Here are the steps:
- go to Prerequisites page
- select Packages in the list
- find .NET Framework 3.5 above .NET Framework 3.5 (web installer) and select it
- when prompted if you want to download the package click the "Yes" button
Let me know how this turns out.
Jaradat
I tried this solution but it does't work, also windows 8 request me to download it from internet :(
Teodor
Hi
Jaradat wrote: How to enable .Net framework 3.5 (Includes .Net 2.0 and 3.0) on windows 8 without connecting to internet to dwonload the package>
.NET Framework 3.5 (or newer) can only be installed as a Feature on Windows 8 and 8.1. Thus, an Internet connection is required for install.
Best regards
Teodor Micu - Advanced Installer Team
Jaradat
BUT you should solve this issue ASAP, it's critical and important. not all customers in my country connected to internet.
please i want these issue to be solved to enhance my package setup
Thank u inadvance
I'm afraid we cannot add this improvement (install .Net 3.5 feature offline on Windows 8) because the only way to enable the .Net Framework 3.5 offline on Windows 8 machines is by using the Windows CD/DVD installation.
