abletech
Checkbox - Checked and Unchecked
I have a dialog with these controls inside:
a checkbox
a label
a textbox.
Now, I do so that when the checkbox is 'checked', the label and textbox to be visible and when the checkbox is 'unchecked' the label and the textbox is hidden.
I appreciated the 'Value' of the checkbox with my Properties and Events Published I had two DoAction:
- If my Properties is 1, then put 0
- If my Properties is 0, then add 1
I think in this way to manage the factor 'checked' and 'unchecked'.
In the Control Condition of the label and the textbox I specified that:
- If my Properties is 0 then hide the label and textbox
- If my monster Properties is 0 then label and textbox
How can I do to solve my problem?
Regards
Re: Checkbox - Checked and Unchecked
If you want to achieve this you should proceed as follows:
Select the "Check Box" control from your dialog. In the "Properties" pane set the following attributes for this control:
Property Name : CHECKBOX
Value : checked
Select the "Static Text" control. Now add two control conditions, from "Control Conditions" tab and edit them as follows:
CONDITION : CHECKBOX = ""
ACTION : Hide
CONDITION : CHECKBOX = "checked"
ACTION : Show
Select the "Edit Box" control and repeat the steps from "Static Text" control.
abletech
Now I ran into another problem.
I have a checkbox that when checked makes a textbox enable = true, if not checked makes the textbox enable = false.
Now, in the Published Events checkbox I did two doAction:
- If the properties of the checkbox = "" then I values ​​a variable with 0
- If the properties of the checkbox = 0, then I values ​​a variable with 1
The textbox in the Control Condition I say:
- If the properties of the checkbox = "" or my variable = "0" then DISABLE
- If the properties of the checkbox = 0 or my variable = "1" then ENABLE.
When I create the msi and arrival in the dialog, I do not check checkato and disable the textbox.
Pressing the checkbox is enabled textbox.
Repressing the checkbox, however, the textbox is no longer disabled.
It is disabled if I press another checkbox, or if I choose a value from a combo or if I click on Next (I even put doAction Next).
How can I solve the problem,
Reguards.
mihai.petcu
Can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can see your settings?
