frefol
Problem with using ProductVersion property in filename
I'm not sure when this broke. I just updated to 4.7....but if I specify the ProductVersion property in the filename field (Bootstrapper screen under Media), AI does not see the setup exe that is created.
Put somthing like the following in this field and you'll see what I mean:
myproduct-[|ProductVersion]
This is more an annoyance...Everytime I want to execute the setup from within AI, I get the error "You must first build the project before you can perform this operation."
Frank
gigi
This is a bug of Advanced Installer 4.7. The fix will be available in Advanced Installer 4.7.1 (scheduled for release this week at any time now). Thank you for reporting it.
Best Regards,
Gigi
______________
Gheorghe Rada
Advanced Installer Team
