Hi all,
I'm currently evaluating AI 1.7 and I'm not quite sure how to perform the following task:
1. Check for the existence/value of a registry key (and set a property).
2a. Depending on the result, prompt an error and exit the installer OR
2b. Perform the install of a component depending conditioned on the property I set in step 1.
I've searched this forum and only see basic references to "You need to write a custom action", but never any addtl. details.
So, if I write a custom action, WHEN does it get executed? In MSI, custom actions can be executed at any given time, but AI doesn't allow me to specify exactly when they run.
For my above example, I'd need Step 1 and 2a performed even before ANY dialogboxes get shown.
The next issue: How can I set a global property via my custom action and use it in the components installation as a condition? My code would set a property and then the component should only get installed by using the condition PROPERTY = "true" or something like that.
What am I missing? Can this be done? If so, HOW exactly?
I appreciate any help on this.
