HI,
We are testing advanced installer for our upcoming product and we like it very much. I am stuck at a major part of the installation process and here is what I am trying to do..
On Step 4 of 8 during the installation.. I have to take the input from an editbox and on Next Click I have to call a method in the .NET dll and send the editbox value(string) to the method in the .NET ddl and return the output (string) back to the installer. If it is successful it has to display the returned value on the Step 5 of 8 (or save it to a property so that I can use it during the install) otherwise I has to stop on Step 4.
I have created a .NET ddl (using the link: http://devcity.net/PrintArticle.aspx?ArticleID=339 )and have added that to the Application Folder and also to the temp folder. And I have followed GabrielBarbu's reply on your forum
Link: http://www.advancedinstaller.com/forums ... f=2&t=9444
And I have tried to create a custom action to call from the "UI Custom Actions" but the options:
1) Call function from a standard DLL and
2) .NET installer class action are DISABLED.
Since I could not ADD " Call function from a standard DLL " under "UI Custom Actions" I tried to add it to Install under InstallExecuteSequence. Since it is under Install I am unable to create a published Event on Next button Click and call the custom Action.
Please help.
1) How to call .NET dll during the installation procedure before install (I mean on Next button click on Pushbutton Click and
2) How to send and receive data from a .NET dll. How to call specific method in a dll from the installer.
Thank you.
