Suggestion: An AI project which has been saved as template should contain some identification that it is a template. AI should give a Warning or Error when opening a template aip file directly. It should only be opened as template.
Current template header (identical to an AI project header):
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<DOCUMENT Type="Advanced Installer" CreateVersion="8.1.3" version="8.1.3" Modules="enterprise" RootPath="." Language="en">
<DOCUMENT Type="Advanced Installer Template" CreateVersion="8.1.3" version="8.1.3" Modules="enterprise" RootPath="." Language="en">
This will prevent novice users to use template aip files in the wrong way.
