rnv.kalz
Create a Website/ Application pool using Advanced Installer
I have asp.net MVC published project files and I want to create an ASP.NET website, application pool and change a few settings on the IIS6/7 using Advanced Installer. I was able add the asp.net published project files to the advanced installer project and gave all the information (http bindings, name, etc., ) during the advanced Installer project creation and I was able to build,run and install it successfully ..but I want to give all the information like.. http bindings, website name, application pool name and its settings during the installation process (published asp.net project files are in the setup file)... and then Create the Website and Application pool. Please help. Thanks.
mihai.petcu
Re: Create a Website/ Application pool using Advanced Installer
Hello and welcome to the Advanced Installer Forums,
You can use the sample project from this user guide article as a starting point.
All the setting fields and names( app. pools, bindings, etc ) from the IIS Page are formatted type, so you can reference public properties which will be resolved from user input. This is exemplified in the sample project with the web site name, which is set through a "SetProperty" published event dispatched by the Next button from the BrowseIIS dialog( SetProperty user guide how to ).
