Hello and welcome to Advanced Installer Forums,
It appears you are trying to achieve a per-user install. The advantage of this is that no administrator privileges are required.
In order to make a per-user installer, simply do the following:
- use the "Files and Folders"->"Application Folder" folder to store your application files
- on the "Install Parameters" page, set the "Installation Type" combo to "Per user only". This has the effect of changing the "Application Folder" path from the Program Files folder to something like:
C:\Users\<username>\AppData\Roaming\<your company folder>\<your product folder>\
which is the standard installation directory for per-user installed applications.
Please let me know if this is not what you are looking for.
Gabriel
