I used Advanced Installer some time back to build an ISO file to install a VB6 app using Crystal Reports XI R2 on 30 user's machines. CR (SAP) have brought out 2 new service packs which (they say) I need to install on the PC's.
What is the easiest way of doing this? Do I need to rebuild the Advanced Installer AIP file to create a new ISO or is there a simpler way of just copying over the newer dll's to the correct folders on the target machine?
Thanks in advance!
Peter Tyler
Geneva - Swizerland
