I am creating an installer to deploy via GPO as a User Based Software install on Server 2003. It runs fine Manually and after the install, it opens the readme rtf file perfectly. When run via GPO it installs correctly, but the Readme does not open.
I set this up under Dialogs\Exit Dialog and the Finish Actions tab.
Is the open Readme option a feature that does not work in GPO? Is there a another way to accomplish this?
Thanks for any help
