I'm having a problem runing a java app installed with Advanced Installer. When I try to run the exe file, I get an error message "JNI Exception: Failed to create the Java VM".
I read a few post that try to solve this around the VM parameters, but I tried eliminating the parameters completely but I get the same error message. The weird thing is that the same installer works on some machines and it doesnt on others. I still have not determined what configuration can be linked to the error. I do believe it has to do with the JRE being used. Is there a way to force the app to use the jre I embedded with the app? it seems to be installed fine, but I dont think the app is using it...
