I'm using Advanced Installer 7.7
I have the following scenario:
1. On Media => Multiple instances, i created 9 instances (INSTANCE2 to INSTANCE10)
2. On Product Details => Product Version, I entered 10.2.0009
3. On Upgrades, I checked "Allow side by side installation of different product version"
3. I Build the Setup
4. I install 2 instances, this works fine.
5. I change Product Version to 10.2.0010
6. I generate a new Product Code
7. I build the Setup again
8. When I start the setup.exe just built, I get a dialog where I can either "upgrade all installed instances", or "maintain or upgrade an already installed instance".
In the list below, I will only see my INSTANCE2, but not the default instance which I have set up first.
9. I select INSTANCE2
10. A question appears "An upgrade of the selected instance will be performed. Do you want to continue?". I answer yes
11. Now a dialog "Resuming the ... Setup Wizard" appears, with options "Install" and "cancel". I klick on "Install"
12. After a while, the installation is finished.
13. But when I check the files in the target folder, they haven't been upgraded.
A few things don't seem to work right here:
a) In point 8 in the list above, why am I not allowed to pick the default instance for upgrading? Why only INSTANCE2?
b) In point 11, why a "resume" dialog appears? The installer should not "resume" anything, it should instead just do a normal upgrade install
c) why is there actually nothing installed?
Note that I need to use "multiple instance" as well as "side by side" install, because I want to support the following scenario:
DEFAULT INSTANCE (production) with Version 1.0
INSTANCE 2 (education) with Version 1.0 as well, but needs to be in a separate folder because of different config files
INSTANCE 3 (test) with Version 2.0
Any help would be greatly appreciated
- Urs
