srini
Driver installation crahes
I have created this installer using version 7.5.2. I am installing a driver as part of the installation. The problem I have described below does not happen in all the machines. It happens to be only on some random machines.
The problem is, when the hardware for which the driver is installed, is present in the machine, the installation finishes prematurely. But, during the installation, if the hardware is not present, the installation completes. What could be the problem.
I have attached the aip and log files.
Please let me know if you need more information in this regard.
ModularTest.aip
(177.43 KiB) Downloaded 405 times
ModularTestInstaller.zip
(88.14 KiB) Downloaded 335 times
GabrielBarbu
Re: Driver installation crahes
This is very likely an issue with the driver itself. Try manually installing the drivers on those machines without DIFX and see if the issue still occurs.
Gabriek
Gabriel Barbu
Advanced Installer Team
