Is there a "Build" Property, so the following can be determined?
Set to the name of the build the user installed.
Here is what you can try:
-- go to Table Editor page in Advanced Installer
-- in the left pane select the table "Property" from the list
-- in that table you shall find the property "ProductCode" to which you can set its value as desired
-- also on the toolbar of that page you will see a combobox from which you can select the desired build
