Do you have a 64 bit version of AdvancedInstaller?
If yes, where can I purchase it?
That is correct, here is a complete list with all the features from Advanced Installer.This wizard seems to require an enterprise license. Is this correct?
This could be done much easier, without using mixed installation packages. Here are more details.I have a working MSI project and just need to have one DLL replaced for 64 bit installations.
If only the above mentioned DLL has both a 32 and 64 version then as I said you don't need to use mixed packages.The project has custom actions and custom serial validation through a dll. I'm not sure how much of work will be involved if I want to convert this into a merged 32/64bit EXE setup. Any pointers?
