I have a question on Product Codes and Upgrade codes. Here are the facts.
Product is in 23 languages and I have added the languages in the Setup. Default lang is English.
I have a Trial Version, Full Version and then Additional Content Packs, (Pack 1, Pack 2, Pack 3, Pack 4)
I have seperate installers for 32 bit and 64 bit.
I have a total of 12 AIP project files, (32/64 of Trial, Full and Packs 1-4)
+ If Trial is installed, then Full version should not install and display the msg that says "This product is already installed" - Product Code & Upgrade Code is same for both Trial and Full.
+ If Trial is installed, then Packs 1 to 4, should not install and display a msg, "Missing product....You need the Full version to install, etc" - (What to do for Product Code and Upgrade Code?)
+ If Full is installed, then User can install ANY Packs without any problem - - (What to do for Product Code and Upgrade Code?)
+ What to do for the Product Codes listed in Project IDs tab? Do I have to change each one for all projects?
Ive attached my Excel Spreadsheet as an attachment to show you.
? Also, Where is Package Code? Does AI, not have Package Codes?
