I would be helpful if you could add the Microsoft Access
Database Engine 2010 (Microsoft Office 12 Access Database Engine Object Library) )to the prerequisites?
The download for 64/32 bit Service Pack 1 is located at
https://support.microsoft.com/en-us/kb/2460011
You have the Access 2010
Runtime, but I do not need to have all of my customers install all of that, but instead, just what is needed for ACEDAO.
The application in which needs it is not an Access program and doesn't need the Access runtime.
It only accesses the data in the ACE/Jet database through a Visual Studio program which gets installed as previously olnly the DAO/Jet needed to be installed.
This ACE Engine is the replacement for DAO 3.6 and Jet4 Engine, as can be seen under
https://msdn.microsoft.com/en-us/librar ... Technology "What about the Microsoft JET Engine?".
Thank you!
clint
<EDIT> There is a newer version - SP2 from 07 Jan. 2016
(64bit and x86)
https://www.microsoft.com/en-US/downloa ... x?id=13255
